Latest post 08-03-2009 7:41 PM by Evan. 28 replies.
Page 2 of 2 (29 items) < Previous 1 2
  • 08-02-2009 3:47 AM In reply to
    Re: will a MCP5500 work with a BS4500?
    Laughing
    If your 4500 is two way, look for a Beolink 7000 - far, far better.
  • 08-02-2009 6:06 AM In reply to
    Make absolutely sure that your BM4500 is 2 way as there is no practical means of adding it afterwards.
    Or......
    Dont bother with 2 way and use a BL1000. Much the more sensible option!!!!! IMHODevil
    Regards Graham
  • 08-02-2009 6:59 AM In reply to
    Have to agree with you Graham. Although I would prefer a Beo4 otherwise, but not having a direct PHONO button (or SHIFT for A.Tape2) is a nuisance.
    -mika
  • 08-03-2009 7:41 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    The Beo 4 is what I use, but I can live with the inconvenience of the phono keystrokes as I don't have a phonograph Smile
    Evan
