hi,
i have a small but annoying problem with my beoport. i have it masterlinked into my setup and have a bc1 declared as audio master. everything works, except ...
if i have n.music already on and i launch another system in a link room, the sound on the bc1 goes away. i have to switch the bc1 to another source and then back to n.music for it to work. no big deal, but it's annoying and it should work !
i have already posted on this and then accepted solution is to turn everything off, disconnect from the mains, wait and then turn everything back on starting with the audio master. ok, except even this doesn't work.
does anyone have another solution or fix for this ? thanks for any help,
scott
