Latest post 07-29-2009 4:20 AM by beoaddict. 3 replies.
Page 1 of 1 (4 items)
  • 07-22-2009 2:07 PM
    Third party codes
    Just a short question from a newby beo5 programmer.
    I have set-up the beo5 to my convenience and with respect to all B&O stuff its working great. However, I also added the TVIX xml file from this site in order to control it directly (not thru the BV STB-C). I have not been able to control the TVIX by the beo5 yet.
    What do I do wrong?
    Thanks for your input.
  • 07-25-2009 3:53 PM In reply to
    Re: Third party codes
    kick
  • 07-26-2009 5:56 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Assuming you have downloaded the correct version of the Tvix xml file for your Beo5 firmware, I would try a thing: Create a new zone called Third Parties, for example, and place the Tvix xml  in this zone and test it. If it works, copy all the commands from this zone to the zone you want to have the Tvix button.
    Quim
  • 07-29-2009 4:20 AM In reply to
    Thanks. this worked out for me.
