1st March February 2012
06-05-2007 5:17 AM
All I have a slight problem with my BEOCOM 6000 telephones in that when in use, i can pick up Capital Gold radio on them. Any ideas how to cure this JOn
9 LEE
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.27/avatar.jpg)
![Top 10 Contributor Top 10 Contributor](/Themes/beotheme1/images/rankicons/rankTop10.gif)
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Are you sure you're not holding your radio to your ear? ![Laughing](http://forum.beoworld.org/emoticons/emotion-61.gif)
Keith Saunders
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.92/avatar.jpg)
![Top 25 Contributor Top 25 Contributor](/Themes/beotheme1/images/rankicons/rankTop25.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Interesting problem, I have heard of this type of problem before. Do you live in a flat or high building in London ? If so, is there many flats in teh same block ? Have you always had this problem ? Does it happen to all your BeoCom 6000's ? Does the problem happen all the time or just when you have good weather ?
Just started in the last 2 days, and is affecting 4x com6000 and 2xcom2, i have a netgear wireless router and an airport extreme base station but have had these for years with no issues. I do remember some time ago when my Lab6000 speakers volume was at min you could also hear classic fm thru them even tho they are connected to the BV3 . Must be my house JOn
Daniel
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.24.49/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
sensotronic: I have a slight problem with my BEOCOM 6000 telephones in that when in use, i can pick up Capital Gold radio on them. Any ideas how to cure this
So, which radio station do you want to listen to instead? ![Laughing](http://forum.beoworld.org/emoticons/emotion-61.gif)
Keith Saunders
- Posts 3,810
Sensotronic, So, it started two days ago and has never happened previously ? I would be surprised if the problem was with the Netgear router or extreme base station unless you have made some major changes in the last week ?
Max
![](/utility/anonymous.gif)
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
- Joined on 04-19-2007
- Devon
- Posts 64
I had a similar issue with a BT dect phone and kept hearing Virgin and assumed the callers were listening to background music. I bought a Beocom 2 hoping this would solve the problem (any excuse I hear you say) and the problem persisted, how disappointed was I? Got the B&O bug and bought a Beocom 6000 and 1401 and when installing microfilters in advance of getting broadband and the music stopped. I guess if you have a wireless router you already have microfilters?
Page 1 of 1 (11 items)
