Latest post 01-17-2012 3:42 PM by Nio. 4 replies.
Page 1 of 1 (5 items)
  • 07-09-2009 8:13 AM
    • Peter6
    • Not Ranked
    • Joined on 07-09-2009
    • Posts 2
    PC + Beolab 4 + Beolab 2 subwoofer - how to connect Beolab 2 ?
    I wonder if anybody would be able to help me on how to effectively connect a Beolab 2 subwoofer into a PC + Beolab 4 (Non-PC version) set-up ?
    It would be interesting to see what you might come-up with - I've tried several methods but, although the Beolab 4s work perfectly, the Beolab 2 remains on stand-by and doesn't activate.
  • 07-09-2009 8:50 AM In reply to
    Re: PC + Beolab 4 + Beolab 2 subwoofer - how to connect Beolab 2 ?
    Easiest solution: get a BeoPort & connect the Lab 2 to the BeoPort Powerlink output, then each BeoLab 4 to BeoLab 2!Big Smile
    Reunion Island is greeting you!
  • 07-09-2009 9:08 AM In reply to
    • Peter6
    • Not Ranked
    • Posts 2
    Thanks ... appreciate the quick reply ... that sounds like a quick, easy option ! I'll set-it up and let you know howit goes ...
  • 11-17-2011 6:30 PM In reply to
    • Nio
    • Not Ranked
    • Joined on 10-01-2011
    • Posts 61
    How does it sound? Isn't the Beolab 2 Sub an overkill for BeoLab 4 speakerS?
  • 01-17-2012 3:42 PM In reply to
    • Nio
    • Not Ranked
    • Posts 61
    I replaced my BeoLink PC2 (old Version) with a BeoPort. It now works (nearly) perfectly with the beolab 4 and beolab 2.
    The sound is really cool and it looks perfect with my home office.
    However, When I just hibernate my pc the speakers are still on. so i first have to exit beoport and than hibernate my pc.
    I want to get a BeoLab 3500 soon ..
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
