Yes, the RIAA preamplifier was an option for the Beogram 1000.
Many were mounted, especially for use with the first versions of the Beomaster 900, but for some reason, they are
not very common today.
The build quality of the module is fairly good, the same goes for the electronic circuits. I am not sure however,
if the RIAA module lived 100% up to the actually RIAA specs given, every producer had their own way of doing it, but
the sound quality is normally very good and pleasant, a good match for the Beomaster 1000 with a pair
of contemporary B&O speakers.
Like everywhere else, electrolytic capacitors dry out and cause problems. This could easily be the cause for the
uneven frequency response, you experience.
Of course, this could also be a problem within the Beomaster 1000 (or both).
When mounting the RIAA module, a "blind" or "short-circuit" plate is removed from the socket in the Beogram and the
module installed instead, held by one screw with a fiber washer.
I think I have some of the blind plates if you need one and I'm sure that many people would be interested in the RIAA
module should you decide to part with it.
Unless an optional RIAA was installed in your Beomaster 1000 (it will sit next to the optional MPX stereo decoder),
your Beomaster should have one phono input WITH RIAA and one WITHOUT. Sounds like you have the RIAA in both inputs.
RIAA options were available also for the Beomaster 900M/K but it's very different from the Beomaster 1000 module.
