Latest post 08-11-2009 6:36 AM by tournedos. 7 replies.
Page 1 of 1 (8 items)
  • 07-09-2009 6:15 AM
    Beogram 1000 RIAA?
    I recently got my retipped SP6/7 back and only now had time to try my "new" Beogram 1000. The only amp conveniently available was my Beomaster 1000, which has two phono inputs with different level of amplification. I had no idea which one of them was which, and was a little baffled when I didn't get proper sound from either.
    Then, it dawned to me to try the tape input, which sounded just fine! So, it appears my Beogram has the internal RIAA amp. Was this a common option, and how does its quality compare to those in vintage amplifiers? It sounds a bit too bright to me...
    I may have to bypass it anyway since my planned setup will need the tape input for something else.
    -mika
  • 07-09-2009 8:03 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 1000 RIAA?
    Yes, the RIAA preamplifier was an option for the Beogram 1000.
    Many were mounted, especially for use with the first versions of the Beomaster 900, but for some reason, they are
    not very common today.
    The build quality of the module is fairly good, the same goes for the electronic circuits. I am not sure however,
    if the RIAA module lived 100% up to the actually RIAA specs given, every producer had their own way of doing it, but
    the sound quality is normally very good and pleasant, a good match for the Beomaster 1000 with a pair
    of contemporary B&O speakers.
    Like everywhere else, electrolytic capacitors dry out and cause problems. This could easily be the cause for the
    uneven frequency response, you experience.
    Of course, this could also be a problem within the Beomaster 1000 (or both).
    When mounting the RIAA module, a "blind" or "short-circuit" plate is removed from the socket in the Beogram and the
    module installed instead, held by one screw with a fiber washer.
    I think I have some of the blind plates if you need one and I'm sure that many people would be interested in the RIAA
    module should you decide to part with it.
    Unless an optional RIAA was installed in your Beomaster 1000 (it will sit next to the optional MPX stereo decoder),
    your Beomaster should have one phono input WITH RIAA and one WITHOUT. Sounds like you have the RIAA in both inputs.
    RIAA options were available also for the Beomaster 900M/K but it's very different from the Beomaster 1000 module.
  • 07-09-2009 8:25 AM In reply to
    Thanks. The sound hums a little as well, so I suppose I will have to recap the preamplifier. Seems like the design will bleed AC to the supply very easily if the filter caps are bad.
    Phono 2 on the Beomaster definitely sounded like double RIAA, phono 1 was't quite so distorted - perhaps there is just some connector or switch problem, as I have never tried the phono inputs on it before.
    I'll definitely offer the amp module here on the forum if I end up removing it - I'm not quite sure yet which receiver I'll use with the Beogram.
    -mika
  • 07-09-2009 8:35 AM In reply to
    • Dillen
    • Posts 5,008
    Note that one or two of the electrolytic capacitors are bipolar.
  • 08-02-2009 5:52 PM In reply to
    • DSJR
    • Not Ranked
    • Joined on 11-01-2008
    • Suffolk
    • Posts 31
    late question - I've been away too long it seems - can this unit be used with my 1972 'Gram 3000, or was it a different one?
  • 08-03-2009 3:53 AM In reply to
    • Dillen
    • Posts 5,008
    It can't. The Beogram 3000 uses a completely different module.
    Rarer of course. Erm
  • 08-07-2009 5:20 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Hi Mika,
    Good to see that you're still tinkering!
    You don't need to bypass the Tape input - there are plenty of old KVM (Keyboard Video Mouse) Computer switchboxes around with 5 pin Din Keyboard connectors. Many companies are throwing them away these days.
    Ignore the Video and Mouse connectors (if it has those).
    Find one with a 1-port input + 4-port output. Open it, and you'll see a single diode on the keyboard wiring - remove the diode, and solder the wire directly to the terminal.
    You might want to spray it black to match the vintage B&O colours.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 08-11-2009 6:36 AM In reply to
    yachadm:
    That's a wicked idea! Big Smile Actually a PS/2 switch should work as well as PS/2 and AT keyboards are electrically compatible, but the required adapter cables would probably make it a senseless idea in practice...
    -mika
