Hi, thanks for all the pictures of my pre-amp kit, that was quite a surprise to see them on the thread!
Basically, I have had them made with both RCA and 5pin DIN inputs AND outputs, so you have a choice of connections, but they don't pass Datalink signals through (you would need to unscrew the two extra removeable pins on the Beogram DIN plug to connect it). I can provide a custom cable with Datalink wiring included on request, but the pre-amp kits don't ship with this included as standard.
As Graham mentioned, the newer models in the "Ouverture" range (ie. 3000 and 3200 don't have Datalink, so they are not able to control a Beogram remotely. However, the earlier models (including the Ouverture) do have this facility.
Best regards,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
