hi,
hopefully someone can help.
i have connected a beolink active (with eye) to my av9000 (which is running as a slave off the master avant) so that i can control my sky+ box on the avant (can't be done directly with the av9000), but to get it to work i have to put the tv onto say channel 6, then on the beolink controller i need to find 'link' & go > then 'sat' which then allows me to change channels, however if i then want to say turn the volume down i have to go back to 'tv' and then go back through the process above after - is there a way that i can program a l-sat option or something so that the process can be simpified?
thanks in advance
steve
