Latest post 07-09-2009 6:54 AM by fish. 5 replies.
Page 1 of 1 (6 items)
  • 07-06-2009 8:07 AM
    • fish
    • Not Ranked
    • Joined on 07-03-2007
    • Posts 28
    av9000 and beolink active question
    hi,
    hopefully someone can help.
    i have connected a beolink active (with eye) to my av9000 (which is running as a slave off the master avant) so that i can control my sky+ box on the avant (can't be done directly with the av9000), but to get it to work i have to put the tv onto say channel 6, then on the beolink controller i need to find 'link' & go > then 'sat' which then allows me to change channels, however if i then want to say turn the volume down i have to go back to 'tv' and then go back through the process above after - is there a way that i can program a l-sat option or something so that the process can be simpified?
    thanks in advance
    steve
  • 07-06-2009 9:18 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: av9000 and beolink active question
    You can use a Beolink 1000. This remote is able to change AV9000 volume even it is in LINK SAT mode, and it has a specific button for "LINK".
    You can also use a Lintronic box. This box could send "TV - 6" IR macro command, when receiving -for example- LINK - SAT. So you could activate your AV9000 AND  Avant by pressing just LINK - SAT.
    Hope that helps.
    Stefan
  • 07-06-2009 9:29 AM In reply to
    er, I use my Sky + directly off of my AV9000.............
    What's stopping you do that?
    Cheers
    GUY
    Train Hard - Run Fast - Hit to Kill!!!
  • 07-06-2009 12:28 PM In reply to
    • fish
    • Not Ranked
    • Posts 28
    thanks stefan/guy.
    will look at getting a beolink 1000 and giving that a try first.
    cheers
    steve
  • 07-06-2009 12:32 PM In reply to
    My AV9000 also has a Sky box attached - however I am aware that the STB-C module is no longer easily available. I didn't think the AV9000 could be used as a slave though! Laughing Which model is it?
  • 07-09-2009 6:54 AM In reply to
    • fish
    • Not Ranked
    • Posts 28
    sorry, what i meant to say was, i have an av9000 which i can't run as a slave off the master avant!
    steve
