yes, deleting files is a problem.
i have the following observations:
1. when you delete the files from the beomedia 5 remotely using a computer the Bs5 still displays the album and can still play it which i find bizarre... you would have thought that once deleted from the Bmedia5 dierctory it would disapper completey...
2. when you go into clean-up mode and delete the album using the Bs5 it still holds the music folder on the Bmedia5.
the only way reliable way i have found to delete a music folder is to delete is using both methods one after the other...
