1st March February 2012
Latest post 07-03-2009 7:57 PM by Dave. 14 replies.
07-02-2009 11:39 AM
WDPE
- Joined on 04-02-2009
- Posts 4
Beolab 6000 distorted bass
Hello everybody,
I've been using a pair of beolab 6000 speakers with a beosound 3000 for over 7 years without having any problems or changing the setup in any way.
However, recently, when I turn up the volume just a bit higher then the standard playing volume, the lower sounds seem distorted.
The sounds resembles a sort of resonance, but this isn't the case. Both speakers seem to have got the problem.
Any thoughts?
Kind regards.
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
Re: Beolab 6000 distorted bass
Slide up the front cloth grilles and gently pop them off,
Then play some music at higher volume, and you should see the bass drivers flapping around like a butterfly in a whirlwind.
It will be the driver rubbers split. You will need four, probably.
Seems to be happening quite a lot to the older ones now - i always check ours as a matter of course.
Lee
koning
- Joined on 04-16-2007
- Netherlands
- Posts 2,670
The bass drivers from the beolab 6000 looks like a cheap car speakers.
Why didn't the make a motification for these drivers?
joeyboygolf
- Ely, Cambridgeshire, UK
- Posts 3,252
koning:
I think that statement is an insult...............to cheap car speakers!!
9 LEE
- Moderator - UK
- Posts 5,223
I must agree. Whichever engineer had that plonked in his hand to give the seal of approval to obviously didn't go much on aesthetics.
They're push fit connectors on the back too - not even soldered! In fact, they connect just like cheap car spe..... hey, hang on!
Peter
- Joined on 02-12-2007
- Posts 9,572
In common with a number of B&O speakers, the sum of the parts works rather better than the individual items might suggest. The quality of the drive units is however disappointing as the longevity is not that great. The upside is that they are cheap to replace!
TWG
- Joined on 04-17-2007
- Germany
- Posts 950
Peter :
Than it should be a nice experiment to exchange all the chassis with real(!) high end speaker chassis!? Perhaps than the Beolabs will blow you away!?
Dave
- Brisbane, Australia
- Posts 2,328
why do they use rubbish drivers??
I had a look at my beocenter1 speakers the other day and yeah wow, really rubbish cardboard and foam... i can't say the same for BL4000 though they seemed like much better quality drivers.
Jonathan
- Joined on 05-03-2007
- Melbourne, Australia
- Posts 1,164
Dave:
Ker-ching the almighty $$$
My B&O: 2009 Catalogue and Pricelist
ChrDH
- Denmark
- Posts 493
Yes it is a pity with the 6000, and that is what prevents me from buying a pair. I love my BL4000 (first prize a year ago ), they really seem a perfect mix of sound, design and built quality.
br
Chr
Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
PhilLondon
- London
- Posts 2,545
A friend of mine had the same problem after transporting his 6000.
We removed the cloth and we just had to touch the driver and it poped back in place - and that was sorted.
ChrDH
- Denmark
- Posts 493
What about the driver units in the Beolab 3500, does they have the same problem?
br
Chr
koning
- Netherlands
- Posts 2,670
That's why non b&O people say....you pay for it design
Maybe they are right
Dave
- Posts 2,328
koning:
I think is certainly is the case with these speakers. Yes they are not bad speakers, but... not if you're choosing between them and 4000's. So B&O did make these speakers to a price, but seriously, how much do good drivers cost to use when they are building it from freaking anodised aluminium???
Page 1 of 1 (15 items)
