Hi All,
I was hoping to get your opinions on whether there's a better way to connect my peripherals to my 32" RF Avant (VCR) to get the best quality picture and sound.
As it stands:
Decoder - Virgin V+ (with this STB set to RGB output)
DVD - B&O DVD1
VCR SCART - I have unplugged the SCART going from the inbuilt VCR to the Avant and plugged in an X-Box 360 into the Avant instead
Camcorder - I have my Airport Express plugged into here.
I'm sure I remember someone saying that the Decoder SCART is not RGB so you guys may suggest I plug it into one of the others instead.
FYI, I use the V+ box by far the most, then the DVD player, then the X-Box and airport respectively.
Thanks!
32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
