Latest post 08-07-2009 7:43 AM by Heribert. 7 replies.
Page 1 of 1 (8 items)
  • 06-29-2009 11:56 PM
    Beovision 8-40 connect to mac which connection?
    I am trying to connect a mac powerbook to my Beovision 8-40 and am not sure which connection to make. Do I use some sort of HDMI conversion cable that will plug into the DVI output on the mac? I obviously want the best picture and suspect there is a beter connection thatn the PC one on the BV8. Do such conversion cords exist? I guess they would need to have a phones jack on the computer end to carry the sound.
    How are others making these connections?
    paddy2042
    Patrick
  • 06-30-2009 8:54 AM In reply to
    • jonasrosen
    • Not Ranked
    • Joined on 07-30-2007
    • Stockholm, Sweden
    • Posts 21
    Re: Beovision 8-40 connect to mac which connection?
    There are DVI to HDMI converters available, I used one to connect my BeoMaster 5 (DVI) to one of the HDMI inputs to my BV8-40, you need to set the connection for your MAC on the BV8-40 to HDMI. Hope that helps.
    BV8-40, BV7-32, BL7-1, BS5, BM5, BM1, BL3, BS1, Beocom4
  • 07-01-2009 6:03 AM In reply to
    But for sound what do I do? I obviously go from the headphone jack on the mac (either  a mini headphone jack or optical cable. Where do i plug this into the BV8-40 I don't think there is anywhere to plug this audio.
    Patrick
  • 07-02-2009 5:41 AM In reply to
    It looks like I may need some sort of Toslink to SPDIF cable. I spoke to my dealer and we cannot see any other solution. It is a shame Apple will not put HDMI outputs on their computers. They really show that they want Apple TV to be their Media Centre!
    Patrick
  • 07-02-2009 7:39 AM In reply to
    • jonasrosen
    • Not Ranked
    • Stockholm, Sweden
    • Posts 21
    I am not in front of my setup right now, but I connected the sound via the RCA cables (three sticks in each end, however only using two of them, left, right) to my BV8-40. I will try take a picture when I am in front of my setup.
  • 07-02-2009 7:02 PM In reply to
    If this is using the red and white terminals then the sound is analogue rather than digital. Does it sound OK? I guess it means that you can only get stereo rather than any type of surround sound.I really would like digital sound but I guess I will have to take what I can get with the limitations of the Mac and BV8!
    Patrick
  • 07-03-2009 4:36 AM In reply to
    • jonasrosen
    • Not Ranked
    • Stockholm, Sweden
    • Posts 21
    You are correct, only stereo, no surround. I only used the computer for music,  photos and web browsing when connected to my BV.
  • 08-07-2009 7:43 AM In reply to
    Does the BV8 have a opto/digital entry like TOSLINK?
    This would be great.
    Thanks for the info,
    Heribert
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
