I'm not sure i typed my question right
Thanks for your replies so far i appreciate it.
It already is region 0 (it came from Lee). I assume. it's behaving the same way my BC1 was, and i went into it's service menu and it said it was in region 0, so i changed it to region 4 and have had no problems since. There seems to be no way of checking on my DVD1. No service menu.
There must be a way to change it to my region (region 4). I tried pressing << >> and re-plugging it in, nothing happened.
Being in region 0 means it doesn't play some of my discs, which are ALL region 4... hasn't anybody else experienced this issue? It seems to be a mystery
