1st March February 2012
Latest post 06-22-2009 8:09 AM by Razlaw. 11 replies.
06-21-2009 4:28 PM
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
Hello All
I have set up my apple tv connected to BV7.
am i correct in thinking that to distrubute it around the house it needs to have the audio via Phono plug L+R as you cannot access the sound from link rooms if using HDMI.
Will there be a fix for the HDMI link issues?
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
Ehlerz
- Joined on 04-17-2007
- DK
- Posts 510
Hi
That will be correct, digital signals does not work through ML, thus you need a phonocable to be able to use your appletv for sound in linkrooms.
BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
Seanie_230
- Posts 962
hi there thanks for the quick reply
so the BV7 only has one set of audio phono connectors on AV5, if i download films i will not get Dolby with phono connectors.
does the apple tv digital output output PCM and Dolby as i could use this and connect to SPdif
takktakk
- Joined on 08-11-2008
- Norway
- Posts 88
Ehlerz:
Hi
Or you simply use one of these, and use an iPod Touch or iPhone to choose from your entire music library, and actually showing you what music you have and are currently playing. The Airport Express has minjack out, an most of your B&O systems will have the same as AUX in. This solution is perfect if you already have WiFi (wireless internet) in your house. You also get digital distribution, as there also is digital out on the AP.
If you have a pair of PC or ordinary Beolab 4, or Beolab 3, you don't even need a music system in between. Just connect directly to speakers from Airport Express and let iTunes or your iPod set what to play and at which volume.
Not to crash the party - just wanted to mention it
BV 7-55, BL 7-4, BL 9's, BL 4's, BL 3's, BC 2300, Beo5, Beo4
Ehlerz
- DK
- Posts 510
takktakk:
Ehlerz:
Hi
That would be correct however, if you want to listen to your music in say 4 linkrooms, it is far easier the other way around.
And you are always welcome to join the party :-)
Seanie_230
- Posts 962
takktakk:
Ehlerz:
Hi
thanks for your input but i am now completly lost lol.
i think i will connect it via HDMI for now and worry about the link rooms later.
Does anyone know what the keys are on the beo 4 to contol it as on the apple remote you hold play / pause to bring up the activate genius function but when i hold down go nothing happens?
takktakk
- Norway
- Posts 88
Thanks but, with all due respect, I am not anywhere near the ability to see why that might be easier. Are you sure you know the full potential of what I am talking about?
That said - enjoy your system! We all have our prefs
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
Ehlerz:
I actually dont know that, but i think you should be able to connect through digital AND phono at the same time so you are able to have Dolby SS and stereo depending on the input source.
That is exactly how we have ours connected.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Seanie_230
- Posts 962
Razlaw:
Ehlerz:
ahh ok so just to confirm
you have it connect on AV5 with HDMI and Phono Plugs.
Is this right?
Ehlerz
- DK
- Posts 510
Without beeing absolutly sure, that is most likely how Raslaw has it connected. This setup wil no doubt provide you with everything you need.
Be aware, that for you to access sound in linkrooms from the appleTV, you have to press "AV DTV" or "AV SAT" depending on your remote. Otherwise there will be no sound, as your linktv thinks the sound is provided through coaxial and not ML.
Best of luck
Razlaw
- Illinois
- Posts 1,770
Yes, that is how I have it connected. I use V. Tape and AV V. Tape to access and the Beo 4 contols the Apple TV perfectly.
Page 1 of 1 (12 items)
