Dealer spent quite a while installing my BS5/BM5 this afternoon, but left before I could use properly and ask questions. It's connected to my BV7-40 so isn't an 'audiomaster'.
1) When you select N.MUSIC from the TV screen, using the Beo4, how do you browse and scroll through your music? You can only move forward and back beween tracks?! You have to choose tracks from the BS5. Correct?
2) The BS5 doesn't seem to control what's on the TV screen (which I'm assuming is BM5 based). Select a track on the BS5 and then show the artwork. The TV shows the BM5 menu! Why doesn't it automatically show the track artwork you've selected on the BS5?
3) How do you easily remove tracks from your BM5 using BeoConnect? I guess you have to manually remove them from the BS5?
4) There's no facility to fast forward through a long track?
IMHO this is a much better product connected directly to the speakers. Hmm.
