Latest post 08-09-2009 6:36 AM by Peter. 11 replies.
Page 1 of 1 (12 items)
  • 06-11-2009 9:36 AM
    unlock the region coding for the BeoCenter 2
    How do I unlock the region coding for the BeoCenter 2 MK III version?  I only have acces to region 2 (europe)
  • 06-11-2009 10:26 AM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    Re: unlock the region coding for the BeoCenter 2
    As far as I know, your dealer can unlock the region code. But you loose every right of guarantee.
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 06-11-2009 6:25 PM In reply to
    You have to contact with your local dealer. This is chargeable operation - you should not loose the guarantee.
  • 06-11-2009 8:35 PM In reply to
    Also, I was informed by my B&O technician that there is a limit of 5 region changes. After that it locks permanently. There is no region-free or region 0 option.
  • 06-11-2009 9:38 PM In reply to
    Not true.
    I had a BC2 and it was re-coded to Region 0.
    10%
  • 06-11-2009 9:59 PM In reply to
    I think officially this is not supported even though some dealers may workaround. The modified Beo4 comes to mind. I think the issue is more that some dealers may not know how.
    JK
  • 06-12-2009 1:25 AM In reply to
    The BC2 can be set to Region 0 and play all DVD regions by your dealer. This is regardless of version II or III. Usually your dealer will charge a minimum fee for this opertion. In Denmark it is about USD 200.
    You will not loose your guarantee by this operation.
    I am not aware if  you can do this yourself using the Beo4 or Beo5 but I doubt it is possible.
    Hope above is helpfull.
  • 06-12-2009 2:11 AM In reply to
    In Holland, the dealer can rent this modified Beo4 from the headoffice. 20 seconds work. It's about 40 euros.
  • 08-06-2009 3:30 PM In reply to
    Any update?
    I am looking for free my bc2 region too..
  • 08-06-2009 8:29 PM In reply to
    It would be great if someone with this modified Beo4 used a Lintronic device to decipher the codes that are sent. Then we could all easily do this with a Beo5.
  • 08-09-2009 3:27 AM In reply to
    Hi everyone,
    my BC2 is absolutely code-free, plays everything "in sight".
    It was purchased in Denmark from an authorized B&O dealer in 2004 and I explicitly asked him to make it code-free before shipping it to me which he did although I remember him telling me that it was difficult because there wasn't much "room".
    But it IS possible...........I think you need to add a chip.
    Filed under:
  • 08-09-2009 6:36 AM In reply to
    There are two methods - one is to add a chip - this may well invalidate your warranty but is quite often done by dealers. The second way is to use the special BEO4 mentioned which transmits a special code. I have not seen one of these in action! Sounds like a safer option!
