How do I unlock the region coding for the BeoCenter 2 MK III version? I only have acces to region 2 (europe)
As far as I know, your dealer can unlock the region code. But you loose every right of guarantee.
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
You have to contact with your local dealer. This is chargeable operation - you should not loose the guarantee.
Also, I was informed by my B&O technician that there is a limit of 5 region changes. After that it locks permanently. There is no region-free or region 0 option.
Not true.
I had a BC2 and it was re-coded to Region 0.
10%
I think officially this is not supported even though some dealers may workaround. The modified Beo4 comes to mind. I think the issue is more that some dealers may not know how.
JK
The BC2 can be set to Region 0 and play all DVD regions by your dealer. This is regardless of version II or III. Usually your dealer will charge a minimum fee for this opertion. In Denmark it is about USD 200.
You will not loose your guarantee by this operation.
I am not aware if you can do this yourself using the Beo4 or Beo5 but I doubt it is possible.
Hope above is helpfull.
In Holland, the dealer can rent this modified Beo4 from the headoffice. 20 seconds work. It's about 40 euros.
Any update?
I am looking for free my bc2 region too..
It would be great if someone with this modified Beo4 used a Lintronic device to decipher the codes that are sent. Then we could all easily do this with a Beo5.
Hi everyone,
my BC2 is absolutely code-free, plays everything "in sight".
It was purchased in Denmark from an authorized B&O dealer in 2004 and I explicitly asked him to make it code-free before shipping it to me which he did although I remember him telling me that it was difficult because there wasn't much "room".
But it IS possible...........I think you need to add a chip.
There are two methods - one is to add a chip - this may well invalidate your warranty but is quite often done by dealers. The second way is to use the special BEO4 mentioned which transmits a special code. I have not seen one of these in action! Sounds like a safer option!
