Latest post 02-16-2012 1:35 AM by valve1. 33 replies.
Page 2 of 2 (34 items) < Previous 1 2
  • 01-28-2012 9:12 AM In reply to
    Re: How to open a Beogram 4002 / 4004 / 6000
    Can't we make this a sticky? Smile
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 01-28-2012 10:30 AM In reply to
    A reasonable request! On the removing the wood surround, you don need to remove the control panel but after that it is just a case of removing the screws that hold the panel in the sliding position. There are plastic parts below the screws which are rather fragile but take your time and they can be re-used.
  • 01-28-2012 11:36 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    I just want to add a couple of little things - You should really follow the correct proceedure of bending the release tabs before moving the plinth forward. These lock the plinth in place which is why it appears to stick on some machines. By not bending these you needlessly wear them out to the point that many plinths just slide forward easily on their own accord.
    Secondly, on re-assembly you might find some motor panels are a little stuborn and will not easily allow the plinth to lock into postition. This is rectified simply by lifting the panel up by a tiny (less than 1/2mm maybe but experiment!) amount and then sliding the plinth in should be effortless. Seems the keyhole can catch on the upper, larger diameter part of the pegs sometimes - maybe because it has become slightly bent out of shape?.. whos knows. Not worth messing with and once you know how to tease it in it isn't a problem!
    Olly.
  • 02-15-2012 1:03 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-11-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    @Mika and other Mods:
    Should this "sticky" be converted to a Wiki for the new Forum?
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 02-15-2012 1:32 PM In reply to
    Not a bad idea at all! We'll see about it once the ball is rolling, so to speak...
    -mika
  • 02-15-2012 1:56 PM In reply to
    I like the idea of making how-to/description entries out of threads like these Smile
  • 02-15-2012 1:59 PM In reply to
    Søren Hammer:
    Same here, the new forum will have to have them and more
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 02-16-2012 1:35 AM In reply to
    • valve1
    • Top 500 Contributor
    • Joined on 05-27-2009
    • Dublin Ireland
    • Posts 213
    • Gold Member
    Rich:
    That's new forum thinking!
