Thanks for your reply.
For the heating, i don't really know. I used the beomaster with my
computer to listen to music on beovox P45. One evening, i forgot to
swith the beomaster off. The lusic was stopped but not the beomaster
wich was on TAPE input, and not very loud. Next morning, i saw the
beomaster was on, but i didn't touch it. When i came back to the
computer in the afternoon, the beomaster was switched off, and i
couldn't switch it on. So i changed the fuse (one was burned). But since, nothing happens when i will switch it on.
I did the rorating etc...., and the power switch doesn't have oxidation. The fuses are correct also, but it doesn't work.
I'm not very easy for mesuring the transformer, rectifier, etc....
I would prefer to give the beomaster to repar, but here, People in Beoshop are not very sympatic, so i don't know were to go.
Thanks again
Zazou
