Latest post 06-20-2009 2:14 AM by Dillen. 7 replies.
Page 1 of 1 (8 items)
  • 06-06-2009 2:13 PM
    • zazouzt
    • Top 500 Contributor
    • Joined on 04-17-2007
    • near Strasbourg/France
    • Posts 123
    Beomaster 3000-2
    I bought recently another beomaster 3000-2 (mine had a problem with the radio), to put on my desktop, beneath the computer.
    Since a week, no problem, but yesterday i forgot to stop it, this morning it was on, but this afternnoon it was out, and i couldn't put it on again.
    I changed the 2 fuse (one of them was burned), but it doen't work.
    what could it be ?   some one has an idea .....?
    zazou
  • 06-11-2009 6:54 AM In reply to
    • zazouzt
    • Posts 123
    Re: Beomaster 3000-2 heat problems
    No one has an idea ?
    Zazou
  • 06-11-2009 4:51 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    If there's no power at all, you will have to look at the fuses once more.
    Unplug from mains and rotate the voltage setting switch a couple of times back
    and forth to break through eventual oxidation - remember to set it correctly again
    before plugging back into mains.
    The power switch can also have oxidation, that's very common but not as easy to fix
    in that the switch itself needs to be taken completely apart and de-oxid'ed.
    If all this is fine, you will have to measure around a bit. Transformer, rectifier
    and so on. The little square rectifier on the tuner board is a well-known troublemaker, though unlikely to
    be the cause for a completely dead set.
    Along with the electrolytic capacitors, I like to replace this rectifier on every machine coming in here.
    What's that about the heat problem ?
    Did it become very warm on the cooling fins ?
  • 06-12-2009 9:11 AM In reply to
    • zazouzt
    • Posts 123
    Thanks for your reply.
    For the heating, i don't really know. I used the beomaster with my computer to listen to music on beovox P45. One evening, i forgot to swith the beomaster off.  The lusic was stopped but not the beomaster wich was on TAPE input, and not very loud. Next morning, i saw the beomaster was on, but i didn't touch it. When i came back to the computer in the afternoon, the beomaster was switched off, and i couldn't switch it on. So i changed the fuse (one was burned). But since, nothing happens when i will switch it on.
    I did the rorating etc...., and the power switch doesn't have oxidation. The fuses are correct also, but it doesn't work.
    I'm not very easy for mesuring the transformer, rectifier, etc....
    I would prefer to give the beomaster to repar, but here, People in Beoshop are not very sympatic, so i don't know were to go.
    Thanks again
    Zazou
  • 06-12-2009 4:09 PM In reply to
    • Dillen
    • Posts 5,008
    I will be happy to take a look at it but since I am in Denmark I'm afraid shipping back and forth
    will be a bit costly. Surely someone nearer you can help ?
  • 06-13-2009 10:44 AM In reply to
    • zazouzt
    • Posts 123
    Yes, i found some one. I Phone to the the Beoshop dan they gave me an adress.
    I'll look at this in the next days, and let you know when it's done.
    Zazou
  • 06-19-2009 7:32 AM In reply to
    • zazouzt
    • Posts 123
    I accepted an estimate, and would know what you think about :
    they charged a secondary supply kit and 6 hours of work  for  138€ + local charges (Tva)
    Zazou
  • 06-20-2009 2:14 AM In reply to
    • Dillen
    • Posts 5,008
    I am not sure what that "secondary supply kit" contains but 6 hours work sound a lot.
    Still, it doesn't sound expensive for 6 hours work.
    If the repair cost is acceptable is for you to decide. I've seen nice working BM3000's sell
    for much more than that.
