I had thought that I bought my 1203 Beogram turntable in 1971 but find on the main site that they were only manufactured from 1974(!)
It still has the original cartridge which I removed for inspection today and was suprised to find that it is an SP10. References on the mainsite suggest that the standard cartridge for this turntable would have been the SP14, and there are references elsewhere on the forum to the SP12. So my questions are:
Was the SP10 the correct cartridge in my original purchase (or had the dealer possibly switched cartridges???)
If I need to replace the SP10 at some point (seems OK at present) do I have to go for an SP10 rebuild or is there a better replacement?
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
