Hi all,
I'm having a bit of trouble getting my recently purchased surround sound module to work on my 8323 Avant.
It's a 4019 and the compatibilty with the tv looks fine in the Monitor Info.
The instructions say to solder the 2R2 resistor that came in the pack at location 14R11. It only says R11 on the circuitboard and there's already a 2R20 resistor there. Am I right in assuming the work's already been done for me and no further soldering is required?
Also, the instructions seem to indicate I need to fit new chips into IC1 & 1C2 on PCB6. The chips currently there both have V3.5 on - do they need updating?
I hooked up the flat wire that connects the module to the TV's circuit board and then set about connecting my speakers. They're passive non-B&O so I've obtained a 5din-RCA lead to run from my FRONT PL outlet to my amp which is subsquently connected to a pair of JBLs.
When I select SPEAKER on the remote I can't change it from speaker 1 to speaker 2 or 3. It's as if the new set up isn't recognized.
Other than a sound check is there a way to see if the module is correctly installed? Or am I potentially in need of a SW update?
Any help or advice would be much appreciated.
Thanks a lot!
