Hi
I have a Beosound 4 and an ipod touch. Is it possible to connect the two wirelessly?
By themselves, no. You can however connect your computer to the BS4 and then use the iPod Touch to control iTunes through the BS4.
Hi Peter
Thanks for your quick response.
My BS4 is connected to my computer via Beoport. I can connect my iPod directly to the BS4 and it will play the music I select from the iPod. Can I connect my iPod to the BS4 wirelessly?
Steve
you can only control your iTunes library on your computer using the iPod Touch or the iPhone using the remote control app, which you can download for free from the iTunes store.
You cannot connect the BS4 and your iPod directly.
