Latest post 05-26-2009 5:58 PM by gk31ax. 4 replies.
Page 1 of 1 (5 items)
  • 05-25-2009 10:14 AM
    • steev
    • Not Ranked
    • Joined on 05-25-2009
    • Posts 3
    Wireless connection
    Hi
    I have a Beosound 4 and an ipod touch.  Is it possible to connect the two wirelessly?
  • 05-25-2009 10:35 AM In reply to
    Re: Wireless connection
    By themselves, no. You can however connect your computer to the BS4 and then use the iPod Touch to control iTunes through the BS4.
  • 05-26-2009 5:44 PM In reply to
    • steev
    • Not Ranked
    • Posts 3
  • 05-26-2009 5:45 PM In reply to
    • steev
    • Not Ranked
    • Posts 3
    Hi Peter
    Thanks for your quick response.
    My BS4 is connected to my computer via Beoport.  I can connect my iPod directly to the BS4 and it will play the music I select from the iPod.  Can I connect my iPod to the BS4 wirelessly?
    Steve
  • 05-26-2009 5:58 PM In reply to
    you can only control your iTunes library on your computer using the iPod Touch or the iPhone using the remote control app, which you can download for free from the iTunes store.
    You cannot connect the BS4 and your iPod directly.
