Latest post 05-25-2009 3:07 AM by Keith Saunders. 4 replies.
Page 1 of 1 (5 items)
  • 05-22-2009 12:30 PM
    Sat Receiver Force D-Master 1144S
    Hi all,
    i have the chance to buy an external sat receiver, model is Force D-Master 1144S.
    The seller states it would work with B&O remotes.
    In the user guide is also mentioned, that these receivers with an additional option are compatible to Beo4.
    I just tested it with my B&O equipment.
    It doesn't work with Beo4 and there is no obvious menu item in the setup menu regarding B&O.
    How can i figure out, whether this receiver has the B&O option or not?
    Any help is very appreciated,
    Kiwi
  • 05-22-2009 1:52 PM In reply to
    Re: Sat Receiver Force D-Master 1144S
    The Force D-Master will work if either:-
    • It is a Force D-Master compatible model, it will have a label on the bottom of the unit to say so; OR
    • It is connected to a Beovision with the STB-C or PUC set to Force D-Master
    If the unit is a B&O compatible model, then it uses the AVL signal on the SCART
    Regards Keith....
  • 05-22-2009 3:34 PM In reply to
    Thanks Keith,
    there is no label at the bottom.
    Bad luck for the seller.
    Kind regards,
    Kiwi4all
  • 05-23-2009 8:37 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Sorry Kiwi, the seller is right. You can control EVERY Force D-master with Beo4/5 via STB-controler or PUC. The box is on the list since many years.
    You will also find a solution by www.oneremote.dk.
    Stefan
  • 05-25-2009 3:07 AM In reply to
    The seller is apparently selling a B&O compatible Force D-Master and so is advertising that it is a unit which will work using the "AVL" signal on the SCART connector, in other words NOT using the PUC/STB-C
    It is true that the D-Master has been available in the STB-C and PUC for a long time, but the seller does not know the configuration of the buyers equipment.
    Force being a Danish company produced several STB models each in two types B&O compatible and NOT compatible, the difference being the decode of the B&O commands on the AVL which means you do NOT need a STB-C or PUC to control it via your Beovision with the Beo4/5. The Beo4/5 IR signal goes into the Beovision and is sent out on pin 8 of the SCART to the STB
    Regards Keith....
