Hi all,
i have the chance to buy an external sat receiver, model is Force D-Master 1144S.
The seller states it would work with B&O remotes.
In the user guide is also mentioned, that these receivers with an additional option are compatible to Beo4.
I just tested it with my B&O equipment.
It doesn't work with Beo4 and there is no obvious menu item in the setup menu regarding B&O.
How can i figure out, whether this receiver has the B&O option or not?
Any help is very appreciated,
Kiwi
