Latest post 05-22-2009 9:02 AM by stephen290361. 2 replies.
Page 1 of 1 (3 items)
  • 05-21-2009 7:48 AM
    Beomedia set up some problems
    Hi guys,
    I have been installing a BM to my B&O system over the past couple of days I purchased it from a B&O shop (used) I have managed to get it running after several reboots and amendments to the display I can view the BM on my network and I can access it through my vista op lap top using bm-user, but the folder "bm user" - all though showing shared in BM is not diplayed. I also have a beoport installed on a XP running machine and that has has picked up the bm, but needed to be shown address first. I am assuming looking at the bm user folder through the bm Service facility that the user permission ony has administrator in it's list do I need to add "bm-user"? Don't know how but could find out just need to know if I have to as I don't want to waist more of my time. I am still a littlle unsure how to use the Beoport to transfer the files but if that is the only way then I will have to learn more.
    I have in my ML a beovision 7 / beosound 9000 / beoport / 2 off beovision tv (old ones) / beomedia1 (i think) is it possable to view on my other beovision tv's the bm in the sam way as bv7?
    I know the above is a lot to ask but I would be grateful.
    Kind regards
  • 05-21-2009 8:40 AM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Re: Beomedia set up some problems
    Try this
    Open your Windows Explorer and type in the adress bar
    \\IP\bm-share$\ (IP is the Beomedia IP)
    When prompted to login enter the following:
    User: bm-user
    Password: *** (your password)
    You should see now a hidden folder where you can put your files
  • 05-22-2009 9:02 AM In reply to
    HI Gerd
    Thank you for your quick response I tried it but without any success. I did however go through on the service menu and shared the data directory which got me in to bm-user folder.
    I'm sure I will be on the site soon for more advice.
    Thanks again.
