Hi everyone
looking at buying a BM1900 off ebay. Seller claims all is working fine except one light for the balance slider which doesnt appear a big issue. My question is, does this unit support datalink? ie with the correct turntable will the BM start turntable playback when the phono input is selected? I believe the BM2400 will do this and I also believe the only difference between them is the actual ultrasonic remote control, hence wondering if the 1900 will still provide datalink functionality.
Andrew
