Latest post 05-19-2009 8:19 PM by Andrew. 2 replies.
Page 1 of 1 (3 items)
  • 05-18-2009 7:29 PM
    • Andrew
    • Not Ranked
    • Joined on 03-16-2009
    • Melbourne, Australia
    • Posts 49
    BeoMaster 1900 does it support datalink?
    Hi everyone
    looking at buying a BM1900 off ebay. Seller claims all is working fine except one light for the balance slider which doesnt appear a big issue. My question is, does this unit support datalink? ie with the correct turntable will the BM start turntable playback when the phono input is selected? I believe the BM2400 will do this and I also believe the only difference between them is the actual ultrasonic remote control, hence wondering if the 1900 will still provide datalink functionality.
    Andrew
  • 05-19-2009 1:47 AM In reply to
    Re: BeoMaster 1900 does it support datalink?
    No it does not, and the 2400-2 does not use Datalink either - only a proto version that is only fitted to very few decks - 2400/2/4 and 4004.
  • 05-19-2009 8:19 PM In reply to
    • Andrew
    • Not Ranked
    • Posts 49
    oh okay, I was under the impression the remote of the BM 2400-2 would start the record playing when the Phono input was selected... I must be getting my receivers mixed up... Thanks for the help Peter :)
