My beo 5 for some reason has stop charging. This seems to be after upgrading to software version 2.2 when it preformed the firmware automatic upgrade to 1.40a . Since then my Battery level always is empty and if I leave iton the charger (i have 2 chargers which both have been tested to work) it will not charge.
If i take it off the charger it lasts a couple of seconds then says 'recharge battery' on the display ??
Any Ideas ?
Also I tried removing the 3 screws at the bottom of the beo5 (on the charge pad) all teh connectors internally were fine. But i was wondering how you could access the rechargeable battery inside .....anyone got a service manual ?
cheers
Scott
