Latest post 05-14-2009 10:09 AM by joeyboygolf. 4 replies.
Page 1 of 1 (5 items)
  • 05-13-2009 11:56 PM
    Powerlink Cable Problem
    Hi All,
    I've just moved into a new home and am installing my Beolab 3s and Beolab 4000s.  I've made up some Powerlink cables using some 8-pin DIN connectors and some Cat7 SSTP ethernet cable that I already had.  The cables carry audio nicely, but the speakers don't turn themselves off when I power down my sources.
    I found some advice on an old thread at the DIY Audio forum, (http://www.diyaudio.com/forums/showthread.php?threadid=35464),  and, based on that and the BeoWorld technical guide, here's what I've done:
    Pin 1 - ON/OFF - Blue ethernet wire
    Pin 2 - Audio Ground - Ethernet screen
    Pin 3 - Left Audio - Brown ethernet wire
    Pin 4 - ON/OFF - Yellow ethernet wire
    Pin 5 - Right Audio - Green ethernet wire
    Pin 6 - Data - not connected
    Pin 7 - Data ground - not connected
    Pin 8 - APHC - not connected
    I've only connected one wire in each of the ethernet cable pairs (there isn't room in the pins to solder in both wires in each pair).  I've also not (yet!) connected the APHC - I'm not sure if I should do or not.
    I'm stumped as to why the speakers don't turn off properly, since both of the ON/OFF pins are wired correctly and I've checked my soldering with a multimeter.
    I'd be really grateful for any advice as to how to solve the problem!
    Regards,
    Simon.
  • 05-14-2009 3:37 AM In reply to
    Re: Powerlink Cable Problem
    Have you read this
    http://www.beoworld.org/beotech/misc2.htm#Audio Aux Link / PowerLink connections:
    Regards Graham
  • 05-14-2009 6:38 AM In reply to
    • msd575
    • Not Ranked
    • Joined on 05-03-2009
    • Posts 1
    • Silver Member
    The Beolab 4000 require a PowerLink Mk1 or Mk2 cable, while the  Beolab 3 require a PowerLink Mk3 cable. This is due to the difference of power amplifier (IcePower Class D versus Call A/B). In the Powerlink MK3 cable, the Pin 7 must be connected to the ground. Here the Mk3 connection :
    Pin 1 - Not used
    Pin 2 - Audio Ground - Screen
    Pin 3 - Left Audio - Brown wire
    Pin 4 - ON/OFF - Yellow wire
    Pin 5 - Right Audio - Green wire
    Pin 6 - Not used
    Pin 7 - Data ground - Blue wire
    Pin 8 - Not used
    Regards,
    Marc
  • 05-14-2009 9:15 AM In reply to
    Thanks for your responses.  I've read the technical article; I didn't know the differences between Mk1/2 and Mk3 Powerlink cables.  Will my Lab 4000s work properly with a Mk 3 cable?
    I'll make up some new cables to the Mk3 spec and try them again with the Lab 3s!
    Regards,
    Simon.
  • 05-14-2009 10:09 AM In reply to
    The 4000's will be fine with the Mk3 spec
    Regards Graham
