Hi All,
I've just moved into a new home and am installing my Beolab 3s and Beolab 4000s.  I've made up some Powerlink cables using some 8-pin DIN connectors and some Cat7 SSTP ethernet cable that I already had.  The cables carry audio nicely, but the speakers don't turn themselves off when I power down my sources.
I found some advice on an old thread at the DIY Audio forum, (http://www.diyaudio.com/forums/showthread.php?threadid=35464),  and, based on that and the BeoWorld technical guide, here's what I've done:
Pin 1 - ON/OFF - Blue ethernet wire
Pin 2 - Audio Ground - Ethernet screen
Pin 3 - Left Audio - Brown ethernet wire
Pin 4 - ON/OFF - Yellow ethernet wire
Pin 5 - Right Audio - Green ethernet wire
Pin 6 - Data - not connected
Pin 7 - Data ground - not connected
Pin 8 - APHC - not connected
I've only connected one wire in each of the ethernet cable pairs (there isn't room in the pins to solder in both wires in each pair).  I've also not (yet!) connected the APHC - I'm not sure if I should do or not.
I'm stumped as to why the speakers don't turn off properly, since both of the ON/OFF pins are wired correctly and I've checked my soldering with a multimeter.
I'd be really grateful for any advice as to how to solve the problem!
Regards,
Simon.
