Latest post 01-23-2011 4:34 PM by pacificocean. 6 replies.
Page 1 of 1 (7 items)
  • 05-13-2009 1:42 AM
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    beolink 5000 screen fallen out!
    has anyone heard of this before? i just received one but it arrived in two pieces :(
    i've placed the screen the position for it, but the pixels are all muddled and there's nothing stopping the screen from falling out agian :(
  • 05-13-2009 2:22 AM In reply to
    Re: beolink 5000 screen fallen out!
    Many years ago I had a poor condition BL5000 that had pixels broken and the screen loose. I didn't pay much for it and was aware of it when I bought it. I used a bit of super glue to fix the screen itself in place.
    Sounds like you got a broken screen... They are very expensive to replace. I was quoted something in the range of 300 euro when I asked B&O service some 7 years ago.
    I ended up giving it away and getting a brand new one instead.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 05-13-2009 4:48 AM In reply to
    • Dave
    • Posts 2,328
    Oh no! Well the screen works, but the electronic connection is broken (that ribbony part) it just seems like it needs to br afixed... 300 euros, dear lord
  • 05-13-2009 7:31 AM In reply to
    • archie
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Paris
    • Posts 497
    The screen of the Beolink 5000 is a part of the mainboard, not like the Beo4.
    if you change the screen you must change the mainbord, 250 euros in france.....
    DU BEAU, DU BON, DU BO.
  • 05-13-2009 8:31 AM In reply to
    • Dave
    • Posts 2,328
    The screen doesn't need to be changed, it just need to be re attached to the electronic ribbon strip.... is this possible though?
  • 05-13-2009 8:47 AM In reply to
    Someone with good soldering skills might be able to help you. But from what I remember the connecting strip is very delicate and small, like a computer component.
    -Andreas
  • 01-23-2011 4:34 PM In reply to
    I have 2 BL5000 remotes one with only a loose screen and one with a loose screen that does only show partial characters.
    • Is it possible to restore the conection of the screen to the mainboard? and
    • what is the best way to fix the glassscreens?
