Latest post 01-28-2010 4:16 PM by Dillen. 19 replies.
Page 1 of 1 (20 items)
  • 05-12-2009 12:34 PM
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Beocord 6500 How to replace belt!!!!!!
    I am trying to replace the belt on my Becord 6500. Its the wide belt.....I can't figure out at all how to put it on. The thin ones are easy, just the wide belt. If anyone can help me, I'd be very appreciative.
    Durban South Africa
  • 05-12-2009 12:45 PM In reply to
    Re: Beocord 6500 How to replace belt!!!!!!
    hi bensa
    try to download the servicemanual as you are  a gold member its a little tricky as it's a autoreverse mechanism and difficult to explain.by the way it's the same mechanism as the 7000 if that servicemanual is available
    regards
    jan
  • 05-12-2009 12:54 PM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Hi Jan
    Unfortunately there are no service manuals for the 6500 or 7000 on the site.
    Ben
    Durban South Africa
  • 05-12-2009 1:02 PM In reply to
    Hi Bensa
    I will try to get a diagram how the belt is mounted.
    regards
    jan
  • 05-12-2009 1:06 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    BenSA:
    Hi Jan
    Ben
    There is for the BC5500 - is that different, I'm not sure it is!
  • 05-12-2009 1:17 PM In reply to
    Puncher:
    Worked for my 6500 - although I think it wasn't much help in the actual belt replacement. I just dismantled the mechanism enough to remove the old completely stretched out belt and replace it with a new one. Will be a little bit difficult if the old belt has dropped out and there's no reference  Sad I seem to recall there was one not so obvious gadget that had to be removed to get the belt in the right route...
    I will probably do this again with a BC7000 in very near future, I'll take pictures if the problem is still relevant then.
    -mika
  • 05-12-2009 1:40 PM In reply to
    Hi Puncher
    You mean  Beosystem 5500 right?
    regards
    jan
  • 05-12-2009 1:59 PM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    The Beocord 5500 only shows circuit diagrams, no mechanical parts.
    Durban South Africa
  • 05-12-2009 2:00 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hi Jan.
    I am sure Puncher meant Beocord 5500, and although it looks identical to the Beocord 7000 regarding the buttons and the enclosure, there are visible differences in the cassette loading tray.
    I guess therefore, that they are two different animals.
    Andy T.
    Poor me, never win owt!
  • 05-12-2009 2:07 PM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Here is a cellphone pic of where I am with taking the mechanism apart. Am I at least on the right path?
    Durban South Africa
  • 05-12-2009 2:10 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Ben,
    I have email'ed some instructions, photos and text, hope this helps.
  • 05-12-2009 3:35 PM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Thanks Martin, you have an e-mail
    Durban South Africa
  • 05-12-2009 5:52 PM In reply to
    Andy is correct - the Beocord 6500/7000 is a different beast to the 5500 despite looking externally very siimilar. The 5500 has three motors, the 6500 just one. Have a look at Beocentral for a good description. Not much difference in performance though!
  • 05-12-2009 6:23 PM In reply to
    BenSA:
    I also want to change the belts on my Beocord 7000.
    Do you know what dimensions of the belts are (or are the old ones the same size as when they were new?)
    Where can you buy the new belts?
  • 05-13-2009 2:20 AM In reply to
    @ BenSA,
    I have replaced the belts on my Beocord 7000. Fellow Beoworlder Dillen has kindly supplied me the belts and the information on how to fit them properly. I will PM you with more details on how this is done. For some reason my Beocord 7000 still doesn't work. It's been sitting here for far too long now, and it's time I had a look at it to get i working again.
    @ Damatt
    There are two versions of the Beocord 7000 and they have different belts. Again something I learned from Dillen.
  • 05-13-2009 2:59 AM In reply to
    • Puncher
    • Posts 9,588
    Peter :
    Andy is correct - ...............................
    Surprise - LINK
  • 01-28-2010 12:19 PM In reply to
    Smile [:)] Re: Beocord 6500 How to replace belt!!!!!!
    hallo dillen,
    can you send me info   BC 6500 replace belt
    regard
    peter12345
  • 01-28-2010 3:28 PM In reply to
    • Dillen
    • Posts 5,008
    Welcome to Beoworld !
    Sure.
    You have a PM. Check your inbox at the extreme top right corner of this page.
  • 01-28-2010 3:45 PM In reply to
    hallo dillen,
    Can you send me the info too,  BC 6500 replace belt.
    /*Michael
    BeoVision 4 - 50 HD -  Beo5 - Beolab 5 - Beolab 7-1 - Beolab 6000 .
  • 01-28-2010 4:16 PM In reply to
    • Dillen
    • Posts 5,008
    Of course !
