1st March February 2012
Latest post 01-28-2010 4:16 PM by Dillen. 19 replies.
05-12-2009 12:34 PM
BenSA
- Joined on 04-16-2007
- Durban, South Africa
- Posts 808
Beocord 6500 How to replace belt!!!!!!
I am trying to replace the belt on my Becord 6500. Its the wide belt.....I can't figure out at all how to put it on. The thin ones are easy, just the wide belt. If anyone can help me, I'd be very appreciative.
birgerbum
- Joined on 03-15-2009
- Posts 230
Re: Beocord 6500 How to replace belt!!!!!!
hi bensa
try to download the servicemanual as you are a gold member its a little tricky as it's a autoreverse mechanism and difficult to explain.by the way it's the same mechanism as the 7000 if that servicemanual is available
regards
jan
BenSA
- Posts 808
Hi Jan
Unfortunately there are no service manuals for the 6500 or 7000 on the site.
Ben
birgerbum
- Posts 230
Hi Bensa
I will try to get a diagram how the belt is mounted.
regards
jan
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
BenSA:
Hi Jan
Ben
There is for the BC5500 - is that different, I'm not sure it is!
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Puncher:
Worked for my 6500 - although I think it wasn't much help in the actual belt replacement. I just dismantled the mechanism enough to remove the old completely stretched out belt and replace it with a new one. Will be a little bit difficult if the old belt has dropped out and there's no reference I seem to recall there was one not so obvious gadget that had to be removed to get the belt in the right route...
I will probably do this again with a BC7000 in very near future, I'll take pictures if the problem is still relevant then.
birgerbum
- Posts 230
Hi Puncher
You mean Beosystem 5500 right?
regards
jan
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Hi Jan. I am sure Puncher meant Beocord 5500, and although it looks identical to the Beocord 7000 regarding the buttons and the enclosure, there are visible differences in the cassette loading tray. I guess therefore, that they are two different animals.
Andy T.
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
Ben,
I have email'ed some instructions, photos and text, hope this helps.
Peter
- Joined on 02-12-2007
- Posts 9,572
Andy is correct - the Beocord 6500/7000 is a different beast to the 5500 despite looking externally very siimilar. The 5500 has three motors, the 6500 just one. Have a look at Beocentral for a good description. Not much difference in performance though!
damatt
- Joined on 09-14-2007
- Posts 190
BenSA:
I also want to change the belts on my Beocord 7000.
Do you know what dimensions of the belts are (or are the old ones the same size as when they were new?)
Where can you buy the new belts?
beocool
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
@ BenSA,
I have replaced the belts on my Beocord 7000. Fellow Beoworlder Dillen has kindly supplied me the belts and the information on how to fit them properly. I will PM you with more details on how this is done. For some reason my Beocord 7000 still doesn't work. It's been sitting here for far too long now, and it's time I had a look at it to get i working again.
@ Damatt
There are two versions of the Beocord 7000 and they have different belts. Again something I learned from Dillen.
Puncher
- Posts 9,588
Peter :
Andy is correct - ...............................
- LINK
peter12345
- Joined on 01-28-2010
- Posts 1
hallo dillen,
can you send me info BC 6500 replace belt
regard
peter12345
Dillen
- Posts 5,008
Welcome to Beoworld !
Sure. You have a PM. Check your inbox at the extreme top right corner of this page.
talisman
- Joined on 05-06-2007
- Posts 52
hallo dillen,
Can you send me the info too, BC 6500 replace belt.
/*Michael
BeoVision 4 - 50 HD - Beo5 - Beolab 5 - Beolab 7-1 - Beolab 6000 .
Page 1 of 1 (20 items)
