yes i did try A.AUX, same result.
i actually think it has to do with the options, but i tried a lot of combinations, none of them work correctly. apple is connected correctly for sure, as soon as i connect my BL6000 to the BS3200 everything works fine, except that i cant get the sound of the TV then.
but maybe this would be the correct way to do this? connect the speakers to the BS3200 and link to the MX4000? but what would be the correct option programming then?
cheers and thanks again
tom
