Latest post 05-13-2009 4:39 AM by stefan. 5 replies.
Page 1 of 1 (6 items)
  • 05-12-2009 11:55 AM
    link issue...
    hi all,
    i am new here so please be gentle... Smile
    i have a MX4000 linked to a BS3200. a pair of BL6000 are connected to the TV.
    now if i watch TV, speakers come on, no problem. same if i listen to CD or RADIO. but if i try to listen to an AUX source (where i have my apple airport express connected) nothing happens...
    any ideas?!
    cheers and thanks in advance...
    tom
  • 05-12-2009 2:49 PM In reply to
    • MikaelB
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Herning, Denmark
    • Posts 191
    Re: link issue...
    I assume that your Airport is connected to AUX on the BS3200.
    Could it be that when you press AUX, it turns on the MX4000 AUX input.
    I have not ever had this exact setup, but maybe you could try pressing AV button followed by AUX.
    /MikaelB
  • 05-12-2009 3:09 PM In reply to
    Re: link issue...
    hi mikael,
    thanks for your reply. indeed my airport express is connected to the AUX of the BS3200. tried AV followed by AUX, nothing. nothing happens when i press the actual AUX button on the BS3200...
  • 05-12-2009 5:55 PM In reply to
    Re: link issue...
    Have you tried A.AUX on your remote ?
    Are you sure that options are set correctly ? (if radio and cd works, should be ok)
    Sure, your source is connected to A.AUX not PowerLink ?
    Try to increase volume on your Apple ?
    If won't help, reconnect whole system.
    regards,
    Michael
  • 05-12-2009 7:54 PM In reply to
    Re: link issue...
    yes i did try A.AUX, same result.
    i actually think it has to do with the options, but i tried a lot of combinations, none of them work correctly. apple is connected correctly for sure, as soon as i connect my BL6000 to the BS3200 everything works fine, except that i cant get the sound of the TV then.
    but maybe this would be the correct way to do this? connect the speakers to the BS3200 and link to the MX4000? but what would be the correct option programming then?
    cheers and thanks again
    tom
  • 05-13-2009 4:39 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: link issue...
    Assuming your BS3200 and MX400 are masterlinked with a 1615 Beolink Video converter , connect the BL6000 to the audio system and try A.OPT 1 and V.OPT 1. This should let your BS3200 and BL6000 start up when pressing RADIO CD, A.AUX.... Choosing a video source - TV, DTV, DVD...- will activate the Beovision - BS3200 will stay off (standby). If you want to watch TV with sound on BL6000 just press AV - TV (DTV...).
    Hope this helps.
    Stefan
