1st March February 2012
Latest post 05-13-2009 5:01 AM by nbohemen. 16 replies.
05-12-2009 9:59 AM
nbohemen
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.14.46/avatar.jpg)
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 02-09-2009
- Posts 80
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
I bought a second hand MCL2 AV, but I think it might be broken.
There is a current coming in from my MCL2 P, but I don't see a standby light op the transceiver.
How can I be sure if it's broken or not?
Please help!
stefan
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.99/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
- Joined on 04-16-2007
- 200 miles from Struer
- Posts 1,733
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Can you describe how you set it up? Cables, Beomaster....?
If you have a BL 1000 press LINK - 2 - STORE. Does the LED react?
Does the MCL2P you connected the MCL to work?
Stefan
stefan
- Posts 1,733
Sorry, I don`t know what you mean by "the green lead that gives power...".
I don`t think you will get the MCL2P activated by an MCL2AV. You will need a special PL cable with PIN 1 and 4 bridged.
Setup should be: BM5550 -> SPEAKER2 out -> MCL wire -> MCL2AV ( -> IR Transceiver) -> Beolab speaker
MCL2P has an LED which is red in standby and green when activated....(??)
Stefan
Christian
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.87/avatar.jpg)
![Top 100 Contributor Top 100 Contributor](/Themes/beotheme1/images/rankicons/rankTop100.gif)
- Copenhagen, Denmark
- Posts 626
Is the MCL-2AV connected to mains? AFAIR it needs it on power supply.
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
nbohemen
- Posts 80
The transceiver is connected to the MCL 2 AV through a bundle of coloured cables. The green one is the cable that gives power to the transceiver.
But it does not give any power.
Your setup differs from mine in the way that I don't have beolab, but instead MCL 2 P + passive speakers.
What is this special PL cable? If have a MkIII powerlink cable connected.
Christian
- Posts 626
Well that should be fine.
Sorry, that was my only guess.
Christian
- Posts 626
Nico van Bohemen:
You need PowerLink mkII, also known as fully wired.
stefan
- Posts 1,733
MCL2P is meant as a linkroom amplifier. It can not activated by powerlink. powerlink sends a signal (5V) on PIN4 to start a speaker, the MCL2P amplifier needs a signal on PIN1. Usually an MCL2P is activated by an MCL2A connected to the speakers sockets (they are the same as SPEAKER 2 out of a Beomaster). MCL2P will activate the Beomaster/Beosound connected via Powerlink. Possible setups:
- Beomaster - MCL2AV - Beolab (or MCL2P with special PL cable, but no speaker-on delay)
- Beomaster - Powerlink - MCL2P - MCL2a(s) - passive speakers
Doesn`t your MCL2AV work at all? I remember when I connected an MCL2A to an old BM3300 everything worked fine but not the LEDs on the IR transceiver....
Stefan
Gerd
![](/utility/anonymous.gif)
![Top 150 Contributor Top 150 Contributor](/Themes/beotheme1/images/rankicons/rankTop150.gif)
- Joined on 04-20-2007
- Germany
- Posts 523
I'm pretty shure it works with a fully wired PL cable, no need for a special one!
@Nico
Connect the MCL2AV to a Beomasters SPEAKER2 output, then check the following voltages in the MCL2AV:
- on the MCL cable white wire you should read approx. 5V (data from Beomaster) - on the MCL cable pink wire you should read approx. 8V (supply from Beomaster)
- at DC IN (from MCL2P) you should have approx. 15V
If the transceiver LED is still not lit disconnect it and check if you have 5V (where the green wire was connected)
If there's no 5V check the output voltage of both voltage regulators near DC IN socket. You should read 12V on the first and 5V on the second one.
If there's 12V but no 5V your MCL2AV is probably broken.
nbohemen
- Posts 80
Thanks Gerd,
I'll try this and give you the results.
The drawing you added is exactly my setup. Other repliers argued about the possibility of my setup.
I hope it's not broken, then I have to get a new one, because a broken MCL 2 AV makes the MCL 2 P worthless.
Page 1 of 1 (17 items)
