Latest post 05-13-2009 5:01 AM by nbohemen. 16 replies.
Page 1 of 1 (17 items)
  • 05-12-2009 9:59 AM
    MCL2 AV
    I bought a second hand MCL2 AV, but I think it might be broken.
    There is a current coming in from my MCL2 P, but I don't see a standby light op the transceiver.
    How can I be sure if it's broken or not?
    Please help!
  • 05-12-2009 10:09 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: MCL2 AV
    You have to connect your MCL2AV to the MCL out of your Beomaster. Powerlink on MCL2AV is an output not input. Did you connect a power suplly to the MCL2AV?
    Stefan
  • 05-12-2009 10:12 AM In reply to
    Re: MCL2 AV
    I understand what you're saying. That is exactly the way I connected it.
    The MCL2AV gets its power from the MCL 2 P, but I don't get a standby light on the transceiver
  • 05-12-2009 10:14 AM In reply to
    • stefan
    • Posts 1,733
    Re: MCL2 AV
    Can you activate it by pressing the mute button?
    Stefan
  • 05-12-2009 10:19 AM In reply to
    Re: MCL2 AV
    No
  • 05-12-2009 10:25 AM In reply to
    • stefan
    • Posts 1,733
    Re: MCL2 AV
    Can you describe how you set it up? Cables, Beomaster....?
    If you have a BL 1000 press LINK - 2 -  STORE. Does the LED react?
    Does the MCL2P you connected the MCL to work?
    Stefan
  • 05-12-2009 10:31 AM In reply to
    Re: MCL2 AV
    Setup is cables from beomaster 5500 to the MCL 2 AV. Then powerlink to MCL 2 P.
    Transceiver is connected. I don't see an LED at all. The green lead that gives power to the transceiver doesn't give any current.
  • 05-12-2009 10:42 AM In reply to
    • stefan
    • Posts 1,733
    Re: MCL2 AV
    Sorry, I don`t know what you mean by "the green lead that gives power...".
    I don`t think you will get the MCL2P activated by an MCL2AV. You will need a special PL cable with PIN 1 and 4 bridged.
    Setup should be: BM5550 -> SPEAKER2 out -> MCL wire -> MCL2AV ( -> IR Transceiver) -> Beolab speaker
    MCL2P has an LED which is red in standby and green when activated....(??)
    Stefan
  • 05-12-2009 10:49 AM In reply to
    • Christian
    • Top 100 Contributor
    • Copenhagen, Denmark
    • Posts 626
    Re: MCL2 AV
    Is the MCL-2AV connected to mains? AFAIR it needs it on power supply.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 05-12-2009 10:50 AM In reply to
    Re: MCL2 AV
    It is connected to the MCL 2 P via a DC cable.
  • 05-12-2009 10:52 AM In reply to
    Re: MCL2 AV
    The transceiver is connected to the MCL 2 AV through a bundle of coloured cables. The green one is the cable that gives power to the transceiver.
    But it does not give any power.
    Your setup differs from mine in the way that I don't have beolab, but instead MCL 2 P + passive speakers.
    What is this special PL cable? If have a MkIII powerlink cable connected.
  • 05-12-2009 10:56 AM In reply to
    • Christian
    • Posts 626
    Re: MCL2 AV
    Well that should be fine.
    Sorry, that was my only guess.
  • 05-12-2009 10:58 AM In reply to
    • Christian
    • Posts 626
    Re: MCL2 AV
    Nico van Bohemen:
    You need PowerLink mkII, also known as fully wired.
  • 05-12-2009 11:01 AM In reply to
    Re: MCL2 AV
    I don't see why the transceiver doesn't work depending on the powerlink cable.
    As far as I know, MK II is only for data to beolab speakers?
  • 05-12-2009 2:30 PM In reply to
    • stefan
    • Posts 1,733
    Re: MCL2 AV
    MCL2P is meant as a linkroom amplifier. It can not activated by powerlink. powerlink sends a signal (5V) on PIN4 to start a speaker, the MCL2P amplifier needs a signal on PIN1. Usually an MCL2P is activated by an MCL2A connected to the speakers sockets (they are the same as SPEAKER 2 out of a Beomaster). MCL2P will activate the Beomaster/Beosound connected via Powerlink. Possible setups:
    - Beomaster - MCL2AV - Beolab (or MCL2P with special PL cable, but no speaker-on delay)
    - Beomaster - Powerlink - MCL2P - MCL2a(s) - passive speakers
    Doesn`t your MCL2AV work at all? I remember when I connected an MCL2A to an old BM3300 everything worked fine but not the LEDs on the IR transceiver....
    Stefan
  • 05-12-2009 4:00 PM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Re: MCL2 AV
    I'm pretty shure it works with a fully wired PL cable, no need for a special one!
    @Nico
    Connect the MCL2AV to a Beomasters SPEAKER2 output, then check the following voltages in the MCL2AV:
    - on the MCL cable white wire you should read approx. 5V (data from Beomaster)
    - on the MCL cable pink wire you should read approx. 8V (supply from Beomaster)
    - at DC IN (from MCL2P) you should have approx. 15V
    If the transceiver LED is still not lit disconnect it and check if you have 5V (where the green wire was connected)
    If there's no 5V check the output voltage of both voltage regulators near DC IN socket.
    You should read 12V on the first and 5V on the second one.
    If there's 12V but no 5V your MCL2AV is probably broken.
  • 05-13-2009 5:01 AM In reply to
    Re: MCL2 AV
    Thanks Gerd,
    I'll try this and give you the results.
    The drawing you added is exactly my setup. Other repliers argued about the possibility of my setup.
    I hope it's not broken, then I have to get a new one, because a broken MCL 2 AV makes the MCL 2 P worthless.
