jsallen999:
Can anyone advise how to access the lithium battery in a 9500 please?
John
I am very much in favour of the DIY approach, indeed, I have been known to tackle most jobs and hang the concequences.
The lithium battery is situated on the microprocessor board which ideally should be removed from the 9500.
I cannot recommend this as a job for the novice as some batteries are soldered in. This could involve the use of a large soldering iron and the risk of explosion of the battery.
Not all batteries are soldered but there is a risk that your is.
It cannot take a B&O technician more than an hour to do this particular job so in this instance I recommend that you get a quote from your B&O dealer.
