An MCL2 AV is a mastercontrol link device. Would be difficult to use it in an ML system.....
When you activate the AV9000 in video mode, SPEAKER 3 mode will be activated by default, but you will only get mono (center) sound.
Starting AV9000 in audio mode will activate SPEAKER 2 mode, so you will get no sound. Maybe you should try V.OPT 1 and A.OPT 1 in your setup...
The STB controller is for STBs connected to AV2 port in V.AUX mode. To connect an additional DVD player (+ STB) you can use a SCART-expander.
(www.oneremote.dk ?) or Beo. If you connect the DVD player to the LX, you can only use it in the linkroom.
Yes you can use the VX7000 connected to the LX - only in linkroom. To activate VX9000 from linkroom press LINK - V.TAPE.
Stefa
