Hello Keith and thank you for your quick help.
I forgot to say that my BV9 does not include a HDR module.
Unfortunately, the replacement template does not work (I made the same change on this line: stLogicalConnect="TV:DTV:DVD:DVD2:V.MEM:V.AUX:V.AUX2:PC:CAMERA").
What happens in this case?
The VMEM option appears in the sources logical connections if I do not check the DTV module in BV9 Selected Product Datas.
But unfortunately when I assign VMEM to a source, the selection is not memorized.
If I check the DVB-T/S EU Module, the VMEM choice does not appear in the Source Logical Connections.
Have a nice sunday,
Yann.
Ne pas s'en faire et boire frais!
Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
