Latest post 05-11-2009 4:02 AM by BenSA. 12 replies.
Page 1 of 1 (13 items)
  • 05-09-2009 10:00 PM
    Beocenter 9300
    I have a Beocenter 9300 that automatically switches itself off after about an hour, but there are no programmes in the machine! Can anyone advise how to clear what appears to be a phantom programme.
    John
  • 05-09-2009 10:50 PM In reply to
    Re: Beocenter 9300
    Hi
    I think it has to do with the timer/clock funcktion try to unplug it from the mains in approx 5 minutes and plug it in again.ore change the lithium battery inside the 9300.
    regards
    jan
  • 05-09-2009 10:53 PM In reply to
    Re: Beocenter 9300
    Hi John
    Oh! and welcome to beoworld
    regards
    jan
  • 05-10-2009 3:29 AM In reply to
    Re: Beocenter 9300
    birgerbum:
    Hi
    regards
    jan
    @ birgerbum
    Your universal cure for problems with BC9000/8500/9500/9300 seems to involve changing the lithium battery!
    I have direct experience of many of these fine systems and I have never had to change the lithium battery.
    Can you quote examples of what has actually been cured by this action or do you simply have shares in the manufacturer of lithium batteries????
    Regards Graham
  • 05-10-2009 3:55 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beocenter 9300
    Always thought that if the internal lithium battery needs replacing the the word "code" is shown on the display?
    CraigSmile
  • 05-10-2009 5:55 AM In reply to
    Re: Beocenter 9300
    Correct, I believe Craig. At least, that is what I have read in one of the service manuals, Can't recall which one!
    Regards Graham
  • 05-10-2009 7:33 AM In reply to
    Re: Beocenter 9300
    Hi Graham
    That was just a suggestion as I once have solved a bc 9500 with somewhat strange problem by chanching the battery.
    regards
    jan
  • 05-10-2009 7:53 AM In reply to
    Re: Beocenter 9300
    Hi  Graham
    A nother thing that came to my mind why don't you suggest a solution as you are expirienced with these machines.
    regards
    jan
  • 05-10-2009 8:27 AM In reply to
    Re: Beocenter 9300
    birgerbum:
    Hi  Graham
    regards
    jan
    I suggest deletion of all preset programs using the built in test menu as outlined in the service manual which can be downloaded from this site.
    Regards Graham
  • 05-10-2009 8:31 AM In reply to
    • Craig
    • Posts 4,855
    Re: Beocenter 9300
    joeyboygolf:
    Think it is the 9500 Graham, but I may be wrong.Laughing
    CraigSmile
  • 05-10-2009 4:04 PM In reply to
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Re: Beocenter 9300
    I suppose that by removing the battery, everything is cleared from the memory. One could then just put the original back. There obviously must be a way to also clear it using the remote.
    Durban South Africa
  • 05-10-2009 5:10 PM In reply to
    Re: Beocenter 9300
    Hi Bensa
    That's what I ment by chanching the battery as I have had a few cases with strange behavior as the battery was low and there was no indication from the display.But I will not make more comments on this issue as there are a few wise guy's who seems to know better.
    regards
    jan
  • 05-11-2009 4:02 AM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Re: Beocenter 9300
    Hi Jan
    I did realise that is what you meant. Smile
    Any advice or suggestion is always worthwhile!
    Durban South Africa
