birgerbum:
Hi
I think it has to do with the timer/clock funcktion try to unplug it from the mains in approx 5 minutes and plug it in again.ore change the lithium battery inside the 9300.
regards
jan
@ birgerbum
Your universal cure for problems with BC9000/8500/9500/9300 seems to involve changing the lithium battery!
I have direct experience of many of these fine systems and I have never had to change the lithium battery.
Can you quote examples of what has actually been cured by this action or do you simply have shares in the manufacturer of lithium batteries????
