Hi all,
im resurrecting this again,
I posted a message at Easter re a dead 5500. Birgerbum gave some advice about cleaning he laser (thanks) to reiterate what happend, I bought this sometime as working ( the seller said it was tested ok before dispatch and I have no reason to doubt his honesty) Any i decided to keep it.
This is what happens : On power up It only displays a decimal point on the display ( dot)- is this normal ?
The transport works normally, one a CD is inserted and play is pressed the the track dispay comes on, the disc will do more or less one revolution then it will spin fast ( not sure if it gets to speed) then stops. the laser assembly seems to track ok however as started previously the laser seems very dim. ( of course I haven't looked into it !!!!!!!! ).
I have cleaned the lens with a cotton bud and some cleaner. Presumably the actual laser and lens is a sealed unit so it won't be dust on the laser itself ?.
I have also pulled up the main pcb and checked all the connection they seem ok. Oh and I forgot to mention it will do all of the above with no disc present as well. I really would like to get this going.
Kind regards
Steve
