Latest post 05-07-2009 2:16 PM by Odin. 10 replies.
Page 1 of 1 (11 items)
  • 05-05-2009 4:18 PM
    • Odin
    • Not Ranked
    • Joined on 05-04-2009
    • Posts 9
    BV7-32 and Pc?
    Hi all
    Im having trouble connecting my laptop to my bv7. Im using a regular vga connection between the two with a vga to dvi-i converter in the television. I have testet that the laptop gives a signal, but i just cant seem to get it onto the tele. I have tried to switch to "PC" etc on my Beo4...
    Can anyone help me out here??
    kind regards
    Odin
  • 05-05-2009 9:46 PM In reply to
    Re: BV7-32 and Pc?
    I thought "PC" was purely audio from the PC
    My BEO4 manual (alphabetic appendix) says
    "PC Select PC in order to use Beo4 to adjust the sound form a Personal Computer connected to your Bang & Olufsen BeoLink system."
    I suspect you need to be using something like V.AUX to pick up an auxillary video source. You can add V.AUX to the LIST function by going therough the normal "add" function.
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 05-06-2009 1:02 AM In reply to
    • Odin
    • Not Ranked
    • Posts 9
    Re: BV7-32 and Pc?
    Hi
    Thanks for the answer, but i have allready tried using the V.AUX with no luck - still black screen
    Odin
  • 05-06-2009 12:59 PM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: BV7-32 and Pc?
    Hi Odin
    As manual says, you have to connect your laptop to AV4. In the connections menu, you have to activate the VGA option.
    I hope it helps.
    Quim
  • 05-07-2009 2:01 AM In reply to
    • Odin
    • Not Ranked
    • Posts 9
    Re: BV7-32 and Pc?
    Hi Quim..
    thx for the answer. But if i have to connect it to av4 i have to use the scart and that was not the idea.... or was it :)
    And how do i activate the "VGA" as u saids??
    regards
    Odin
  • 05-07-2009 2:33 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Re: BV7-32 and Pc?
    Hi Odin
    Maybe the menu on your BV7 is not the same, but I remember it was an AV where you have the option to activate VGA. Don't need to use scart, just VGA to DV-I.
    Quim
  • 05-07-2009 5:26 AM In reply to
    • Odin
    • Not Ranked
    • Posts 9
    Re: BV7-32 and Pc?
    hi and thx for the answer and good pic
    But my menu dosnt look like that at all. I dont have the VGA option.. nor the HDMI.
    Wierd :)
    Odin
  • 05-07-2009 5:27 AM In reply to
    • Odin
    • Not Ranked
    • Posts 9
    Re: BV7-32 and Pc?
    But i have the PC option
  • 05-07-2009 10:38 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Re: BV7-32 and Pc?
    Odin,
    This menu is from a BV7-40 Mk3, but I owned a BV7-32 and I think I remember there was this option too. Maybe I am wrong.
    I have seen today a BV7-32 Mk1 in my store. There is no VGA option in the menu. Dont know if in newer ones this option exists.
    Quim
  • 05-07-2009 1:59 PM In reply to
    • Odin
    • Not Ranked
    • Posts 9
    Re: BV7-32 and Pc?
    Quim
    Ok i see. But i dont understand why i have the DVI-i input if i dosnt have the option of turning it on somehow. It dosnt make any sense to me!
    So i actually dont know what to try next other than to go down to the local dealer and ask him about it :)
    But thanks for all your help... it is greatly appreciated
    Odin
  • 05-07-2009 2:16 PM In reply to
    • Odin
    • Not Ranked
    • Posts 9
    Re: BV7-32 and Pc?
    Hi again Quim..
    I got it working :))) Finally. In the connections menu i had to (In the HDTV option for AV4) activate DVI-i... I dunno why i havnt seen that before.
    Odin
