Latest post 05-31-2007 2:59 PM by petermc. 3 replies.
Page 1 of 1 (4 items)
  • 05-31-2007 12:19 PM
    • milesm
    • Not Ranked
    • Joined on 05-26-2007
    • Herefordshire
    • Posts 2
    Adjustable volume on Beolab 4000's
    I have an Overture with Beolab 4000 & 6000. 6000's are in the lounge (large room with vaulted ceiling) and the 4000's are in the dining room (a smaller room with beamed ceilings). With full system operating the bass & volume from the 4000's is far too much, can I control these seperately. My link to these is the 4 wire powerlink and will be difficult to change.
    Filed under: ,
  • 05-31-2007 12:37 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Adjustable volume on Beolab 4000's
    Firstly welcome to Beoworld. Your best option would be a Beolink Active. This would give you full control of the Overture from the other room(Your post does not say which room the Overture is in) and also let you control the volume of each room. You will need to run  a master link connection beween the two rooms.
    CraigBig Smile
  • 05-31-2007 12:38 PM In reply to
    You need to install a Beolink Active in the dining room connected to the Ouverture with ML cable. Connect the speakers to the Active to have independent control of volume and tone settings in that room.
    S..t! You Beat me Craig
    Regards Graham
  • 05-31-2007 2:59 PM In reply to
    • petermc
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Shepparton, Australia
    • Posts 87
    Another option might be a Wireless 1. Same features as the active with individual control etc but without the wires.
    Peter
