Latest post 05-06-2009 10:55 PM by geearr. 7 replies.
Page 1 of 1 (8 items)
  • 05-01-2009 4:47 PM
    Beocord 8002 with no sound output
    Hi all,
    I finally received my new-to-me 8000 system (beomaster 8000, Beocord 8002, Beogram 8000, two rosewood M100 (huge!) and four rosewood wall hanging P45s.  All the components are in excellent cosmetic condition but I do find a couple of functional issues I need help with.  After cleaning and relube the Beocord 8002 appears to function properly but has no sound output.  I have tried it with two different receivers (the BM8000 and a BM3300).  There is no action from the sound level meter either.  The tape counter appears to work and display properly and the unit responds correctly to the datalink commands from both receivers and from the remote control directly.  I have removed, cleaned and reinserted all the connectors going to board 3 which I assume is where the problem resides.  There is no visual indication of component overheating and no ugly smells while the unit is on and functioning.  The 7 pin DIN cable shows continuity on all 7 pins.  Anyone have a suggestion as to what to try next to get this otherwise beautiful beast to output sound?
    One other mechanical issue is that the tape control door interferes with the spring bar on the inboard side pushing the spring bar down as the door closes.  The door does open properly when I press on the outboard side of the spring bar and it does latch properly but I would like to correct the interference issue.  It appears that the door must attach by sliding in a dovetail slot and it does appear to be improperly seated in that dovetail on the inboard side where the interference occurs.  I don't want to apply too much pressure trying to get it apart if it is attached in some other way.  Do any of you know how to remove the door from the hinge or is that even possible?
    Thanks for your help.
    Jerry
    Filed under:
  • 05-01-2009 7:13 PM In reply to
    • geearr
    • Top 200 Contributor
    • Joined on 03-27-2008
    • Gold Coast, Australia
    • Posts 301
    • Gold Member
    Re: Beocord 8002 with no sound output
    Hi Jerry
    Congratulations on getting such an excellent sound system.  You won’t regret it.  However, it does take some time and effort to get all of the pieces back to their best condition.
    I note that you are a gold member and must have downloaded the service manuals from the site.  These should help you immensely.
    Regarding the lack of sound from the BC8002, in light of the fact that you have neither channel nor PPM readings, I would first have a look at the record/playback relay located straight after the tape head.  If this is sticking or faulty, it might be the source of your problem.  Signal path tracing on these machines isn’t difficult as long as you have some suitable equipment.  If there is no signal going onto board 2 at Plug 9, pins 1and 2 then the problem is on the preamp circuit side and it could be a relay or head problem.  You could also have a look for possible grounding issues and faulty solder joints while you are at it.
    The tape lid should be fairly easy to sort out.  There should be a 1 to 2 mm gap between all of the top panels and if there isn’t, one of the panels has not been set properly.  Taking the panels off isn’t too difficult but you need to take care with all of the plastic pins because at this stage of their life, they break very easily.  The removal sequence is clearly outlined in the manual and if you have any further difficulties, don’t hesitate to ask.
    Regards
    Geoff
  • 05-02-2009 9:51 PM In reply to
    Hi Geoff,
    Thanks for your help!  I'm not sure where to pick up signal ground to test voltage on pins 1 and 2 of connector 9 on board 2, I just don't have much experience with such.  What should I see in the way of signal voltage once I do find a good signal ground?  I did pop the top off the relay and sprayed cleaner in there.  I cannot observe any movement of the relay when switching the tape to play or stop so that could easily be part or all of the issue.  Is there anything special one needs to do to check the output of the tape head?  What should I see on which pins measuring signal output from the head to the connector right next to the relay?  Would you think it better to try to find a good board 3 and sway it out, try to do the component swaps on this one or look for a properly functioning 8002, 8004 or 9000?
    Regards,
    Jerry
  • 05-03-2009 2:36 AM In reply to
    • geearr
    • Posts 301
    • Gold Member
    Hi Jerry
    I am not sure what you have in the way of useful testing equipment but at the very least, you are going to need to have access to a good multimeter.  You really need a scope for the best examination of the signal path but I assume that you haven’t got one.  If you have a multimeter, I would first carry out the following checks.
    The signal from the heads pass to board 3 via plug 8.  Plug 8 has 11 terminals assigned as follows:
    P8.1     Erase signal
    P8.3     Erase ground
    P8.4     Right signal record
    P8.5     Right signal playback
    P8.6     Right sheath ground
    P8.7     Left signal record
    P8.8     Left signal playback
    P8.9     Left sheath ground
    P8.10/11          Empty
    In my case the normal record signal cables are white and the playback signal cables are pink.  The relay simply grounds either end of the head connection to configure a record or playback line.
    With the set switched off and disconnected from the mains:
    Remove the white plug with the head signals, P8
    Measure the resistance across pink and white wires on each channel at the head.
    You are looking for a resistance indication of ±260ohm.
    Now measure the resistance across the pink and white wires at the plug to check that the wiring is OK.  This should also give you a resistance of ±260ohm.
    Put back the plug P8
    Connect one end of resistance meter to the ground, I use the black wire next to the head.
    Measure the resistance at the pink and white terminals on the head
    White should be grounded giving a very low resistance
    Pink will be show ±260 ohms, ie ready for recording.
    These readings should confirm that the playback signal path is not being obstructed at the relay.
    The signal path then goes through the relay to R102/202, the dark red resistors (56ohm) either side of the relay.
    Probe both ends of these resistors and it should indicate ±260 and  ±320 ohm.
    These checks should confirm that you have a good tape head operation and the playback signal should be getting past the relay.  If that is the case then you will need to look further down the signal path for your problem.
    Disconnect the multimeter and operate the tape recorder with the case open in service mode.
    To check the action of the relay
    Switch the unit on and put in an empty tape
    Press REC OPEN
    Press RECORD
    Press STOP
    Repeat RECORD, then STOP
    Watch to see if the relay is moving
    Press Record and the copper contacts come up, press STOP and the contacts go down
    That should keep you going for a while, did you manage to sort out the problem with the tape lid?
    Good luck
    Regards
    Geoff
  • 05-04-2009 1:49 PM In reply to
    If not already solved, check R2 and D13 on PCB3.
    This solved similar problem for my BC8002.
  • 05-06-2009 8:13 PM In reply to
    Hi Geoff,  Thanks for the detailed recommendations.  I was able to follow them and could determine that the head appears to exhibit the correct resistance both at the head itself and at the connector.  The probes at ends of the two dark red resistors showed much lower resistance values than shown in your note.  Probably means the relay is bad.  When attempting to check the operation of the relay as indicated I found that the tape mechanism would no longer work for whatever reason.  Now the head and pinch roller mechanism is properly pulled forward by both solenoids but the motor no longer starts/turns and the mechanism does not latch in position.  On play it clicks forward, stays there for a few seconds and then clicks back.  Neither fast forward or fast reverse work now either.  Neither REC  OPEN or REC buttons appear to do anything.  I must have done something to screw it up as that all did work when I began.  Ugh!  I did some more probing but could not find the cause and don't know where/how the motor is activated.  I assume there is a micro switch somewhere activated when the mechanism is drawn forward.  Any suggestions for this now very obvious amateur?  Thanks.
    Jerry
  • 05-06-2009 8:15 PM In reply to
    Hi guidovangool,
    Thanks for your suggestions.  R@ does appear to be bad and I will check D13 when I can figure out how to get the tape mechanism functioning properly again.
    Jerry
  • 05-06-2009 10:55 PM In reply to
    • geearr
    • Posts 301
    • Gold Member
    Hi Jerry
    Sounds as if you are having fun with this one!!  Not sure what you have done to the tape deck but you could note the following:
    The motor starts as soon as the set is connected to the mains and the display lights come on.  It only switches off when you switch back to standby.  Therefore as long as there is power and the set is switched on, the tape deck motor should run all the time.
    None of the tape transport functions will work without the motor.  However, the solenoids will actuate but will kick out as soon as it realises that nothing is moving.
    Check to see if the motor is turning and the belt is moving.  You may have inadvertently slipped the belt off when you refitted the deck.  Also put a voltmeter across the two terminals on the top of the motor, you should get 13 or 14 volts showing that the power supply is OK.
    See if this helps get the motor running again.
    Regards
    Geoff
